New to the forum just wanting advise on a sensor in a bathroom | Page 2 | on ElectriciansForums
Discuss New to the forum just wanting advise on a sensor in a bathroom in the The Welcome Forum area at ElectriciansForums.net
I agree with Vortigen, get a light fitting with a microwave sensor in. Then the light will automatically turn on when it detects movement. There may need to be some modifications to get a permanent live to ceiling, but it should be possible to remove the switch wiring completely. Having said that I believe any work in a bathroom is notifiable under part P of the building regulations, so you will probably need a professional electrician in.
Welcome, how have you got on?
Reply to New to the forum just wanting advise on a sensor in a bathroom in the The Welcome Forum area at ElectriciansForums.net
Thank you, both. Seems like common sense may have prevailed, and the fellow is indeed going for one of the modern mirrors you mentioned...
I recommend the Manrose Humidistat timer: Humidity Sensors for fans -...
