Qualified in electronics, only did electrical work as a DIY, now retired and enjoying life. Except when the RCD trips for no obvious reason...
Cheers
Jez
Cheers
Jez
Discuss New to the forum, trying to learn about neutral-earth fault troubleshooting! in the The Welcome Forum area at ElectriciansForums.net
I did consider that - until i saw the price of an RCBO - the board has 18 breakers...Rather than having lots of circuits on one RCD, perhaps consider changing the consumer unit to an all-RCBO board.
Firstly, if there are various circuits contributing to the leakage and tripping, it is far less likely to occur.
Secondly, if a circuit trips, you can see which one it is, rather than wondering which of several it might be.
Thirdly, the inconvenience of a trip will be much less if just one circuit trips.
Which brand(s) did you check?I did consider that - until i saw the price of an RCBO - the board has 18 breakers...
I have a Crabtree CU so I think I looked for something that would plug in directly replacing the MCBs - seemed to be about ÂŁ30 eachWhich brand(s) did you check?
For example. Fusebox RCBOs are approx. ÂŁ10 each.
Some makes are a lot more expensive.
I'd ditch the Crabtree board and start again.I have a Crabtree CU so I think I looked for something that would plug in directly replacing the MCBs - seemed to be over ÂŁ40 each
I'm still hoping to find a fault that means I can keep the existing CUPerhaps a dual RCD board with the two highest leakage circuits on opposite sides?
But the fault might still be there...I'd ditch the Crabtree board and start again.
Reply to New to the forum, trying to learn about neutral-earth fault troubleshooting! in the The Welcome Forum area at ElectriciansForums.net
