new to trunking | on ElectriciansForums
Discuss new to trunking in the Electrician Talk | All Countries area at ElectriciansForums.net
sahelectrical
ive not long started commercial doing trunking bends etc any1 know any good guides or tips on making them
try square is trhe correct name for the tool, i believe. there have been a couple of threads a while ago on this very subject. try a search.
Theres a couple of ways of doing them that look good however a lot of jobs specify manufactured bends only.
I usuaslly make them by cutting out the required angle, folding and fish plating however as this requires a great deal of accuracy and is quite time consuming some people cut out half the required angle and overlap, therefore removing the need for fish plates, this method is a lot more forgiving however doesn't look as good as the first method IMO.
I quite often use a 4 1/2" grinder with very thin blades to cut the trunking, if not just a hacksaw.
The more compartments the more difficult. Always check your marks twice and square everything proper.
Essential tools are hacksaw with 32T blade, tri-square, tin snips, pencil, pop rivet gun, 1/8th bit (For rivets) and you will need a protractor for any angle other then 90 deg and an angle measurer for those obscure angles!
use pre manufactured on trunking, they look 100% neater than slef made, the only time you will need to do them yourself is if a corner is a mile out of square
You can't get any angles other the 90 or 45 off the shelf though, also if you have anything other then standard size trunking bends could have a lead time of 4 weeks! Try getting a 10x3 5 compartment 45 in a hurry!
Reply to new to trunking in the Electrician Talk | All Countries area at ElectriciansForums.net
NICEIC Certification Scheme Getting accredited to
I am in almost the same boat, although I am registered for a scheme, and as I have been continuously, I have been told no NVQ required... BUT...
Adding a led strip isn't going to make much difference to the 3 phase balance. No real difference to where a 3 phase machine uses one phase to...
