New Water meter tripping circuits | on ElectriciansForums
Discuss New Water meter tripping circuits in the UK Electrical Forum area at ElectriciansForums.net
Cheshunt
Bit of a head scratcher.... Haven't done any testing yet but thought I'd see if anyone else had come across this...
A client of mine has just had Water meter installed at the front of their drive by the Water Board. Now, a 32A breaker for their power ring is tripping. Not sure how the water board have tapped into their supply but is from adjacent to the meter rather than coming from the board.
Have done a few basic things such as unplugging all appliances just to make sure its not a coincidence. Will call their water supplier tomorrow to ask exactly what they have done and may try changing the breaker as an initial check.
Just wondering if anyone else has experienced similar??
Not as far as I could initially see?
Going back tomorrow so will be able to do some proper investigating and checks.
They have dug up a patch (and filled in) at the end of their drive. Client says they needed to tap into the supply. But no evidence of any activity at the fuse box. Surely, they wouldn't tap into the pre-meter side of their electric supply. Only sketchy info from client so will get a better picture when I speak to the water board tomorrow.
Never heard of a water meter needing an electricity supply
They won't have been anywhere near the electric supply, they will have installed it in the water supply. The clue is in the name 'water meter'
Reply to New Water meter tripping circuits in the UK Electrical Forum area at ElectriciansForums.net
My guess is an earth to N fault in the damaged light fitting. This will become a problem when other devices draw large currents.
Ok I’ll try this when I’m down
