Newbie after advice how to install dimmer switch | Page 2 | on ElectriciansForums
Discuss Newbie after advice how to install dimmer switch in the The Welcome Forum area at ElectriciansForums.net
Ok kool 15w equals 100w bulb, dimmer was suitable to 400w so enough power . Its very faint if you put your ear to switch. All good thankz for your help guyz
Yes see attached
Then you are ok for that load.
Please don’t get confused by this
15w equates to 100w output but not 100w load. ?
Lamp manufacturers state something like this to give your average punter some idea of the equivalent light output. What they mean that the light output of their 15w LED lamp is similar to what you might be expecting from one of the old style 100w bulbs.
To try and get away from this comparison, lamps are quoted as LUMENS. This is the amount of light output.
This is better, because the LUMEN output of a 15watt warm white LED lamp is vastly different to the LUMEN output of a 15watt cool white LED lamp.
Reply to Newbie after advice how to install dimmer switch in the The Welcome Forum area at ElectriciansForums.net
Thank you! I didn't realise the wiring was QUITE that old… I'll replace it carefully.
our dimmer switch stopped working after 7 years so went to replace it at the weekend. When I opened it up, the black wire was in the common slot...
