Newbie - Hello All, Advice on connecting IP44 Switch | on ElectriciansForums
Discuss Newbie - Hello All, Advice on connecting IP44 Switch in the The Welcome Forum area at ElectriciansForums.net
S
shy7g
Hi Newbie to this forum
Can anyone please direct me with the wiring of an IP44 Weatherproof Switch (Greenbrook - WNSW2G-C).
I'd like to use double switch unit as an in-line on/off switching unit. Can someone please tell me which terminals I need to connect the Live, Neutral, etc (power supply to each switch will be off a 13amp plug and breaker unit)
All advice and assistance greatly appreciated
many thanks
Richard
Which terminal number(s) would I need to connect the live out of the switch?
thanks
The other side of the switch from where you connect the live, I can't give any particular number as I don't know which of the terminals you are going to put the live into.
OP: Just follow dave's info in post 5 and you will be sorted.
I presume you are wiring the water-fountain and the wall lights from the same circuit?
being a gang switch each side of the switch controls one set of the contacts.
If you look at the diagram on the switch one toggle closes 1 and 3 and the other 2 and 4
Please get a qualified spark to install the switch for your own safety and that of others
The fact is that you are asking this question about something you should already know.
Reply to Newbie - Hello All, Advice on connecting IP44 Switch in the The Welcome Forum area at ElectriciansForums.net
Often in old wiring, live to the downstairs switch, then in twin (or twin & earth) the two switched lives to the upstairs switch, and a single...
Hi all, first post, please be gentle ;) Iv been involved in a bathroom refurb, nothing major, moving a light fitting and switch. My problem came...
