Discuss Newbie: just introducing myself in the The Welcome Forum area at ElectriciansForums.net
Hi DanWelcome aboard. No pun intended. (Board/forum?) Tut.
Give us a shout about the DIY thing.
i want to put an underground electrical cable from an plug in socket in the house to my outside shed using an extension lead just to use for power tools when required.Is that something I can do myself land what protective covering would I use
Many thanks
About 12 feetI would not recommend burying an extension lead cable. There is no mechanical protection for it unless you put it in conduit. This will have to be 500/600mm deep in the ground.
I would add a switched fuse unit to the house socket circuit and then use armoured cable for the run from the house to the shed. I wouldn't be surprised if the armoured cable would be cheaper than the conduit.
What is the distance from the house to the shed?
Reply to Newbie: just introducing myself in the The Welcome Forum area at ElectriciansForums.net
