- Joined
- Jun 28, 2012
- Messages
- 2
- Reaction score
- 1
Hi,
I am studying for me 91 and am currently practicing on my home. I have found that my garage circuit consisting of a small 2 way CU with 1 of each; ring and lighting circuit (no RCD). I expected to see this circuit connected to the main CU through its own CB but in fact it is connected to one of the ring final circuits (via a double socket as a spur) and the spare 32A MCB in the main CU not used. I believe, but doubt myself, that this is a C2 because of circuit interconnection and that only an FCU (max 13A) could supply more than one spur (but not the lighting circuit).
Is my logic correct, and if not why not? If I am correct would this constitute a C1 rather than a C2? The rest of the circuits are fine. I scratch my head as to why somebody would do this when there is a spare way in the CU and both the dist board in the garage and the CU appear to be just a few years old.
Any guidance would be greatly appreciated. If I am wrong please can you give me an explanation?
Thank you.
FYI I only have Amendment 2011 knowledge.
Thank you.
