Newbie trying to avoid electrocution | on ElectriciansForums
Discuss Newbie trying to avoid electrocution in the The Welcome Forum area at ElectriciansForums.net
DaveRowntree
All,
I'm based in Southampton, and trying to be useful to our local hackspace (somakeit.org.uk) during our move into bigger premises! We need to do some basic electrical work (just extending ring mains, to add loads more sockets) and some little projects which I'll talk about in a separate thread :)
Dave.
Hi Sintra,
Yes of course! However, several of us can easily handle installation work, but I think we'll ask someone to assess what we did and make corrective suggestions. This isn't difficult work, it's just extending circuits already present!
Thanks,
Dave.
Hi and welcome.
Me thinks your landlord may ask for Certification of changes so ask around for a local spark through recommendation.
Thanks guys,
Yeah we know we will need to get it all checked out and certified by someone qualified to do so (I know of someone I could talk to) but we'll do all the donkey work, so any corrective works and testing will be quick and easy for him. And hopefully cheap.
We have very little funds, so we'll source everything via donations and re-cycling, inspecting everything very carefully for damage, and taking only the best looking parts!
We have several quite bright members, so following the wiring regs shouldn't be too hard...
But! Of course, we will get an expert to check and signoff, so we don't cause our (very generous) landlord any problems in the fuure!
Regards,
Dave.
Thanks guys,
Regards,
Dave.
So WTF are you fannying about wasting everyones time on here for???!!!!
Getting someone in to look at it after you've done it all is too late!
To sign off an installation you have to sign your name to the design, construction and initial verification/inspection and testing.
So the person who is going to sign it off needs to be involved in all stages of the work.
You say corrective action will be easily done afterwards, but what if you have used the wrong size or type of cable for the job? You might extend a ring final circuit in 2.5mm when due to factors you hadn't considered it needs 4.0mm.
Being intelligent and reading the wiring regulations is not enough to start doing a job which needs a minimum of 4 years training under a skilled tradesman.
Hi,we Cover Southampton, based in Fareham.
Give me a call maybe we can help you. As said though, if you do the work first, it's too lAte your on your own I'm Afraid. You wouldn't plumb a boiler in then call a gas man would you? Electricity is no different
OK, I know I'm naive in the art of the spark, all i'm suggesting is finding someone willing to advise and ideally sign off. I will involve them in all stages from before work starts. I understand this is a skilled professional taking a number of years training, but this particular job is not complex.
Thank you for your comments, this will make things easier for a small unsupported group of volunteers only trying to make things better for our community. We have no money we need to rely on our skills and resources and take advice from where we can. Paying a tradesman to do all work would blow our budget out of the water!
Dave.
You've read the forum rules about being nice right? You should try it, maybe you'll make more friends that way.
I'm only trying to get advice as to what I need to do to make our unit safe without blowing the whole budget on a sparky.
Don't bother replying I'm not interested in your comments, and I won't read them.
Have a nice evening.
Dave.
Point taken, we'll be in touch when we've decided what the requirements are.
Much appreciated,
Dave.
Reply to Newbie trying to avoid electrocution in the The Welcome Forum area at ElectriciansForums.net
I don't think I'd use it mate even the one line heading then one long paragraph screams ai. And untrustworthy. I don't think much has been edited...
    • Optimistic
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
