Newbie who wants to replace bathroom extractor fan | Page 3 | on ElectriciansForums
Discuss Newbie who wants to replace bathroom extractor fan in the The Welcome Forum area at ElectriciansForums.net
there speaks the prophet of doom^^^^^. :D:D:D:D:D.
That's the problem with maths and physics, sometimes the calculations provide you with information you don't want to hear!!
Makes sense but now you mention it a 12 V shower does sound safe
I have come across in injection moulding machines heaters that run on 5v dc. a 1kw heater element drew 200A
maybe all showers should be 5volts, fed off an isolating transformer in an adjacent room (center tap to earth = +/- 2.5v) shower would be considerably safer but the cable size for 2000A would be bigger than the pipework!!!
hi, thanks for the useful info, but i'm interested in getting a manual fan with a higher flow rate. my bathroom has no window and people take long showers, the current fan almost never speeds up and i have to remove the front plate cover every time just to temporarily increase the speed. :(
the very LAST THING that shower room needs is a manual fan.
Higher through put and longer timer ......
don't give up the day job as that video clip shows nothing.
back to my original post - have you checked the "output" from the vent outside?
Also if you don't have any heating is a shower room the steam will be worse...........
the heater was removed and will be replaced.
i havent checked the outside fan and its been left unchecked for around 40 years. maybe all it needs is a good cleaning, i suppose?
it works, but i'd rather a replace it with a higher power one
I don't think you're understanding the advice being given here.
If the outlet or ducting taking the air away from the fan is knackered, then a more powerful fan will not help.
The one you have there, from the comments I have read (never used one personally) the fan you have is a decent one.
yeah, i think the duct and exit cover need cleaning out the dust/junk.
its not been cleaned since moved into the house .
but now i wana just replace it because the front plate cover of the fan, got lost/thrown away during the cleaning.
You also need to make sure the duct if there is one is installed correctly, that you haven't got unnecessary length, or have sharp turns in it.
Reply to Newbie who wants to replace bathroom extractor fan in the The Welcome Forum area at ElectriciansForums.net
Things might not be quite as simple as that, especially if the vent is in the roof and the ducting will run uphill from the fan to the vent...
Hi all, first post, please be gentle ;) Iv been involved in a bathroom refurb, nothing major, moving a light fitting and switch. My problem came...
