NIC EIC inspection | on ElectriciansForums
Discuss NIC EIC inspection in the Business Related area at ElectriciansForums.net
P
Podgie
I'm soon to have my nic inspection and was after some tips on what to expect? Etc
thanks
col
Yeah, there are stacks of posts on this. However, amongst other things:
- get your certificates in order, ideally completed and in a file
- have all of your test kit ready including lockout kit, proving unit (ideally), meter(s), etc
- have your insurance certificates to hand
- choose 2 decent installation examples
- rehearse some tests at each location and research what the correct results for each test should be.....know which books to use to check
You should have had a leaflet from the NIC stating what you'll need to have ready?
Incidentally, it seems that the inspectors vary quite a bit so there doesn't seem to be any hard and fast rules as to what they'll check. If it's your first inspection get the basics done properly including safe isolation procedure!
Reply to NIC EIC inspection in the Business Related area at ElectriciansForums.net
Niceic dont allow 3rd party QS sign offs, the main problem i found was building control notifications ,we actually paid the local authority the...
