Nice looking / pretty smoke alarms | on ElectriciansForums
Discuss Nice looking / pretty smoke alarms in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Just doing up a property with high spec finish, has been re-plastered everywhere and nice spots etc - can anyone recommend smokes / heat detectors that don't look like they were ÂŁ5 from B&Q? Ideally something small or not noticeable at all? If you've put 12 spotlights in a kitchen I can't imagine many people slap a big white plastic heat detector in the middle of it all?
It looks like that smoke detector is only a concept at this moment in time, The fire angel stuff isnt as ugly as most battery powered and this one is very reminiscent of a Battlestar Galactica Cylon available in silver or white and as ionising or optical models http://www.amazon.co.uk/Jacob-Jensen-optical-smoke-alarm/dp/B0009KS5QM
[ElectriciansForums.net] Nice looking / pretty smoke alarms
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Haha yes that's a bit more Star Trek than subtle! Thanks both of you, a bit of internet searching has found a Bosch one that's very slim and unintrusive but I thought this might be something people had come across before. It seems to be a bit of an untapped market, people spend hundreds on fancy lights then just slap any old smoke detector next to it. Maybe I should design some :)
Well, yes.
There's a couple of considerations though - the smoke detection chamber (i.e. the bit the smoke has to enter to be detected, needs to be of a certain volume, and designed such that airflow/smoke easily enters the chamber.
Second, nobody, really, should be slapping them up right next to a light fitting - it will bias the detector, and may either limit ariflow, or prevent it working. There is a regulation covering this, so the detector must be a minimum of twice the depth of the light fitting away from it.
Other than that - good luck with the design project if you do it!
Cornburn, would you be so kind as to put up a link of that Bosch one so we could have a look please?
Have you found a place that has the Bosch detectors as I found a post about them on AVforums.com
As for the Bosch thing - I contacted them via their website, got passed around a bit, then promised a call back. To be fair to them, they just called me and it now seems that Bosch no longer make smoke detectors at all. Shame, because it was a nice looking thing.
No, not found anywhere. Will keep hunting for something nice looking, need to see some grand designs houses to see what architects have done there to look good!
Have had this complaint from many customers (normally women) saying can you not fit a nice looking detector.
It's a design issue as much as anything - as I think I said earlier in the thread. The Aico/EI units aren't too bad looking, and are reasonably slimline on the standard base.
But designer light fittings they're not.
Reply to Nice looking / pretty smoke alarms in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
