Nice soft bendy tails | Page 2 | on ElectriciansForums
Discuss Nice soft bendy tails in the UK Electrical Forum area at ElectriciansForums.net
the pict
Mentor
Brodick
Why cant I get the same pliable cable for meter tails that SSE uses the stuff I get is as stiff as rebar whereas theirs is really bendy and easy to form if any one knows why this is let me know
P
The difference is the number of strands. 16, 25 and 35mm insulated and sheathed tails are available in both 7 strand and 19 strand versions. My local wholesaler started stocking the 19 strand a couple of years ago and it is much better to work with than the more solid 7 strand.
Be very careful with these EDF were refusing to connect these to their meters last year.
I had a nightmare last year in a communial intake cupboard ended up having to replace about 30 meters of tails because EDF wouldn't connect to the 19 strand tails.
They are technically considered the same as the 7 stranded tails, but EDF were not prepaired to connect them to their meters until they had some kind of approval from their meter manufacturers.
Hopefully its sorted now but dont want anyone to get caught out like i did.
[ElectriciansForums.net] Nice soft bendy tails
The 7 and 19 strand are both 6181Y, made to the same British standard and both fall in to the category of ‘class 2‘ stranded conductors so unless the meter manufacturer has explicitly specified that only 7 strand cables be connected (highly unlikely) then the EDF guy was wrong and you would have had a fair case against EDF.
In my experience EDF seem to go out of their way to avoid actually doing a job most of the time
I was informed by a meter fitter for UK power networks (that was probably actually EDF but I can't remember) who told me that they had been told to remove any 19 strand cables they found in meters and not to fit them themselves.
They were apparently worried that they would not make a good connection (really?).
I know, I've never known any other company put so much effort into avoiding work. Almost every job there is some excuse.
I would expect a better connection than with a more solid conductor. IIRC there were tests done on this subject and published in one of the ESC Switched On magazines, though I can't find the copy here right now. The tests also included straightening and twisting the strands before connection.
with 25mm tails, i pull them up into the CU a few inches extra, strip the ends about 1",then bend ends over when I've got them in a bit of free space. trim ends to get rid of the unequal strands due to bending, then pull down so the ends drop int the main switch terminals. sometimes i even manage to get them thee right way round. :D.
I could do with a few extra inches
I tried that argument. I actually presented all the information i posted above to one of their technical guys who agreed and authorised it.
Unfortunatley when the second engineer came out he refused to connect it too..
I presented the emails from this senior technical guy, but his "senior field manager" disagreed.
In the end i just had to change the tails because the flats needed energizing.
I rang the senior technical guy back a few weeks later, he said they had a meeting and the outcome was that they wanted each meter manufacture to carry out a series of tests (under lab conditions) to certify that the tails would compress properly in the terminals and wouldnt work there way lose after a few simulated knocks and wiggles.
He said unfortunatley they used 5 or 6 manufactures so until they get satisfactory test results back from all of the manufacturers, they will be disallowing them.
@spinlondon these are not tri-rated.
Reply to Nice soft bendy tails in the UK Electrical Forum area at ElectriciansForums.net
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
Why not fit a self contained SPD fed directly from the Henley blocks, and free up a bay? Could probably make one up from whats there, using a...
2 3 4
4K
