M
mikeymoo
When doing notifiable work for an NICEIC assessment, do i need documentation evidence to say ive informed building control?? or do i tell him i have??
How come this thread was moved to business Related???:confused:
Dont know m8 ! what i did was notify building control and then after i got letter from them saying its been logged and the details etc i rang up and changed the address 2 further times saying the jobs been cancelled etc now i have 3 notified letters lol take your pick !
hi kung
are you with nic??
did they ask to see your completed building notice as mine did :eek:
Not with anyone at mo Flukey but even if you dont notify LABC you still wont fail its just a non compliance i know a couple of people this has happend to plus you get time to notify after job completed even if they did ask i only done it yesterday so will take a while to sort.
Regards
Kung
Not with anyone at mo Flukey but even if you dont notify LABC you still wont fail its just a non compliance even if they did ask i only done it yesterday so will take a while to sort.
Regards
Kung
thats correct kung.
on my assesssment i was told that not notifying labc is a non compliance.
if everything else is in order then this is not a problem.
if however you dont pass and have to notify labc after the event they could ask you to expose wall chases etc to prove correct zones etc as ALL work must be notified to labc BEFORE any work starts :eek:
however if you are 100% certain of your abilities and can satisfy scheme providers expectations then you will be fine :rolleyes:
Thats not a bad idea Kung! "Inform LABC about planned work, then after receiving the letter, change the date!" Then subject to passing?? I self certify the work myself! Magic!
Also got a letter saying planned work is logged! genius!!!..;)
Kung for prime minister!!! :cool:
thats correct kung.
Agree Flukey lol
I did say i did notify LABC and as i have all dead test results for them thats them sorted ! will just change it again regarding address/date its been a right pain ive had 2 places postpone the jobs now im doing my own garage CU the LABC told me the assessment notifications are a massive pain in the rear for them as if you pass you can notify in normal way and if fail (you'd have to do something magger stupid to !) you can still go through them they would rather people went that route !
Its a right pain as its £140 for them but £1.70 when you pass the assessment ! :mad:
When you look at requirments it states notify LABC thats it ! not have completed notice. As long as you notify them and have letter your covered.
Regards
Kung.
P.s. plus onece ive passed then the later job notified to LABC i then go back to LABC and tell them its not going ahead now due to no funds etc and can i have my money back ! been told i will get a refund if this happens !
EAT MY SHORTS building control !
Agree Flukey lol
Regards
Kung.
i hope your garage is attached to your house because i did a detached garage rewire and tried to use it for nic assessment and was told i couldnt because the work wasnt notifiable :eek:
Thanks Flukey
Didnt know that, my garage is 10ft from the back of my house and in my garden thought i could. Better replace my main house CU who told you ? NICEIC ? Told LABC about it and they still took my £137.50 and noted it.
Thanks Flukey
nic only class the cable from the house to the garage as notifiable. anything inside is not :eek:
this was confirmed to me when i first booked my assessment in january this year so i had to show 2 other jobs
Pitty i only have 2 dbl sockets and 2 lights on garage cu ! dam ! dam you NICEIC i say !
How does testing etc work then if you replace garage cu ? and if not notifiable is it a minor cert ? as cu ? plus if some person wanted power supplied to a detatched garage etc does this mean the only cert/testing is done on supply cable only and cu and circuits dont need testing/certing or do they class them as minor ? What a grey area m8 !:confused: think i need a chat with Tony cable from NICEIC first thing monday
Cheers
Kung.
How does testing etc work then if you replace garage cu ? and if not notifiable is it a minor cert ? as cu ? plus if some person wanted power supplied to a detatched garage etc does this mean the only cert/testing is done on supply cable only and cu and circuits dont teen testing/certing or do they class them as minor ? What a grey area m8 !:confused:
Cheers
Kung.
i know mate, another stupid rule. i would still notify the job, its just nic wont recognise it for assessment purposes :mad:
Dam if i was also a bricky i could throw in a few bricks and now its attached ! :D and also 2 wall lights and 2 more dbl sockets now i got 4 lights and a ringmain and dig a small ditch and put drainage in and a shower head and thats my shower circuit ! could have a cooker as well and this sounds great give me a break from the mrs and kids !
With regards to the NICEIC assessment. A copy of both EAWR and DOC P must be provided. Can anyone tell me if these need to be in publication format or can they be downloaded copies??.
That will do nicely! cheers mate.. Are you with Niceic yourself? Could do with some info regarding risk assessment for domestic installs.
i am with niceic. the pack they sent you should show all the paperwork they are expecting to see. the assessment itself is quite straight forward. if you are ok with testing and interpreting the results it will be a breeze. best of luck ;)
Wants the score with full scope and limited scope?? How can i be sure i will be grated full scope??. I'm replacing a cu that was destroyed by fire. Was already a split load rcd type. Being changed over to full RCBO.
full scope means you can do everything an electrician would be expected to.
defined scope is for people like kitchen fitters etc that can only do work thats related to their trade
Hi Flukey
Just phoned NICEIC and they confirmed your answer about not assessment subject so saw LABC and changed to my main house cu.
Regards
Kung.
Thanks for info Flukey saved me a revisit !
Do you have the labc out to inspect the job?
if i change my cu for my forthcoming inspection do i need to inform labc before i start? its only a couple of hours to do so could tell them on the same day! Do i send the eic certificate that i have downloaded a template of to labc once i have completed the results and how long does it usually take for them to get it sorted?
inform labc before you do the job. you call them on the day of the job and tell them whether you want them to come that morning or afternoon. the inspector will take a copy of your eic for his records ;)
Niceic assessment info
Business Related
mikeymoo,
flukey,
