Niceic assessment info
That will do nicely! cheers mate.. Are you with Niceic yourself? Could do with some info regarding risk assessment for domestic installs.
i am with niceic. the pack they sent you should show all the paperwork they are expecting to see. the assessment itself is quite straight forward. if you are ok with testing and interpreting the results it will be a breeze. best of luck ;)
Wants the score with full scope and limited scope?? How can i be sure i will be grated full scope??. I'm replacing a cu that was destroyed by fire. Was already a split load rcd type. Being changed over to full RCBO.
full scope means you can do everything an electrician would be expected to.
defined scope is for people like kitchen fitters etc that can only do work thats related to their trade
Hi Flukey
Just phoned NICEIC and they confirmed your answer about not assessment subject so saw LABC and changed to my main house cu.
Regards
Kung.
Thanks for info Flukey saved me a revisit !
Do you have the labc out to inspect the job?
if i change my cu for my forthcoming inspection do i need to inform labc before i start? its only a couple of hours to do so could tell them on the same day! Do i send the eic certificate that i have downloaded a template of to labc once i have completed the results and how long does it usually take for them to get it sorted?
inform labc before you do the job. you call them on the day of the job and tell them whether you want them to come that morning or afternoon. the inspector will take a copy of your eic for his records ;)
mikeymoo,
flukey,
TrueNAS JBOD Storage Server
