Night Club House lights | on ElectriciansForums
Discuss Night Club House lights in the UK Electrical Forum area at ElectriciansForums.net
C
Cindys Club
Hi Guys, I am opening up a night club and the fire offiicer has come round and he states that i need lighting to come on when the fire alarm goes in to alarm
Currently i have some house lights Halogen downlights that are controled by a dimmer switch (Just like the ones at home!!) and i was wondering if an electrican could put a relay accross the dimmer!? so that they go to full brightness.
Cindy x
ive got non maintained EMs.
I will get the electricans to install it. Ive had one out to quote it and hes telling me i need a dimmer panel installed that alone is ÂŁ400. Was looking for some advice so i know if there having me on
how easy / cheap / complex / expensive will depend on how the club lighting is controlled but it wont be a 10min / ÂŁ50 job , probably a fair bit of work unless the lighting controls and fire panel are next to each other.
If you do just need to bring house lights on to full brightness then yes that could be done by installing a relay in parallel with the existing dimmer switching. It's pretty much the same principal as in a fire station when a call comes in the lights come on.
Reply to Night Club House lights in the UK Electrical Forum area at ElectriciansForums.net
Anywhere where the normal lights are dimmed or dimmable the emergency lighting should be of the maintained type. So maintained emergency lighting...
davesparks
