Has anyone ever had any problems with the night storage heaters Des125 ? I have checked the cables the mcb the 20 amp double pole isolator and all is fine. The heaters do work as I have wired them straight into peak electric, for some reason they don’t work on the off peak ?
the weather heater is on the same Fuse board as the storage heaters but that works fine, so I know the off peak supply is available
