Nin compliant Install by another installer and fraid by customer. | Page 2 | on ElectriciansForums
Discuss Nin compliant Install by another installer and fraid by customer. in the Green Lounge (Access Only) area at ElectriciansForums.net
Thanks guys. may wee be worth lettting this thread run for a while :)
Gemserve (MCS) came back and said:
Thank you for your email below. Please note that Planning Permission must be complied with regardless of being an MCS Installation or not. You may find this link useful to determine whether you require Planning Permission Microgeneration Certification Scheme - Planning Information
In answer to your second question, the Planning Permission must be approved for before the installation can be commissioned. It is not possible to create a certificate for a system that has not yet been commissioned. You will need to check the link above to confirm if you are able to have an installation before it has been approved.
If the Certificate was issued before approval was granted, this would be in breach of Section 4.3 of the
MCS Standard MIS 3004 which states “planning permission shall be obtained before work is commenced”.
They didn't asnwer my specifc questions:
What sanctions would be applied to the installer? Who would apply them?
And
Would it affect the My RHI payments if it was proved that the certificate was issused without planning permission?
So I've asked them again :)
Reply to Nin compliant Install by another installer and fraid by customer. in the Green Lounge (Access Only) area at ElectriciansForums.net
Hello all easy cert users, ive been using easy cert since 2001 with no yearly subscription. and also found other people looking for older versions...
