Nissan Almera Heating fuse blowing
Hi it may be a sized motor if you can get to it you can spin it to see if it free failing that the speed Resistor is normally in the ducting pipe work in the foot wells poss have to remove glove box to get at both and try unplugging them one by one until the fuse stops blowing
What's up with you guys, where's your manners? The 'dude' or 'he' is called Pamela. ;)
Apologies to the OP...i remember just how embarrassed i was,when i made this same mistake,at my first "Dogging" meet....:bobby:
