hi i got problem with driver side window switch relay tested an is ok but still not working properly when the engine running will drop window down but lift up the need disconnect relay put back and window going up When the engine is off and ignition on you can drop and lift up. relay model
amp assy-auto p/w
28515317b00
et80-011 12v
jideco 108
amp assy-auto p/w
28515317b00
et80-011 12v
jideco 108
