Guest viewing limit reached
I had an intermittent fault where the RCD tripped, it started around 2 months ago after removing a light for decorating, however the RCD has reset for periods since. Last Friday it tripped and now won’t reset, the bulbs are all ok. We have had an electrician out today for a few hours to investigate/rectify but he couldn’t give a definitive answer after taking down all the fittings and separating the wires, What would the way ahead be??
Thanks for your help in advance
Phil
Southend
No 1st floor lights
Phil004,
Phil004,
