no contiunity reading | Page 2 | on ElectriciansForums
Discuss no contiunity reading in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I have a fluke tester as well, that would be really helpful thank you. Would the above advice work if I connected a switch and turned it on or do the line and switch line have to be connected at the switches?
If you haven't yet fitted switches then just join Line and switch line together.
PM me your email address and I will send you a copy of the guide on the promise that you will read and understand it before doing any LIVE testing
yes join them together like turning the switch on and there is no neutral in switch just switch wire and phase the neutral should have brown sleeving on it
you medan the switched line should have brown sleeving
Reply to no contiunity reading in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Thank you all for your replies and suggestions. I will try to follow up on each one and find a suitable solution. many thanks all
I don't really know if he is or not, but I would have thought an electrician would be able to calculate cable size or know about requirements for...
