C
cambria
Not come across this before but the installation is labelled PME system but there is no earth connection supplied by the distributor. The earth connections are stuffed inside a loose connector in the fuse box and a 4mm cable connected off the incoming water supply, obviously not allowed anyway. Has anyone come across this situation where no earth connection is supplied by distributor and why they would not have done it ?
