No earth on lighting circuit | Page 3 | on ElectriciansForums
Discuss No earth on lighting circuit in the UK Electrical Forum area at ElectriciansForums.net
Batley
Went for an ECR check and found no earth on lighting circuit, board just been updated last year (Wylex 10 way RCD board), phoned the landlord and said someone recommended to put class 2 fitings but walls have metal capping and switches and accessories are brass/ metal fittings but the code is c2,
Am I right or wrong?, I’m confused
even if class 2 fittings are used, a fault L-exposed part (metal back box) will not be detected.faceplate screws in switches coud be at 240V causing injury or death. this used to be addressed by fitting back boxes with plastic lugs back in the 60. definitely a C2.
on a side note, just fitted an extremely expensive LED chandelier. 16kG.in weight. although the driver is clearly marked class 2 SELV, earth leads are provided to the metal casing and to the ceiling bracket. ( the only 240V in the fitting is direct to the driver in sheathed cable.
I think that the best practice guide is a good form of guidance and is worth a read for anyone involved with inspection and testing but I think westward maybe referring to the fact that inspectors rely too much on it and should refer more to bs7671?
Clearly for some it indeed is a good read.
I don‘t think BS7671 gives very clear guidance IMO. It’s just a book with regulations. That’s why there’s a plethora of other publications and why the exam for each new addition is a farce, just testing someones ability on how to use its contents and index pages.
The other publications are a bit more descriptive for us less intelligent, no offence meant. ?
That's what all exams are, just a test to know if the examined reaches their limit of knowledge they know how to find out the relevant information.
When I returned to the industry a few years ago, I paid to go on a 3 day C&G 17th course with my local training college, thinking it would bring me up to speed. I didn't think for one minute it would educate me over all the changes since I'd left, but a flavour of things. We had a very good 5 minute introduction to the course. But after that it went down hill. We could of been looking at Fanny Cradock's 100 top recipes, for all the instruction I was given.
By contrast, I later went on a commercial training establishment, for initial inspection & testing, far more informative.
If I was told a 3 day course for CG 2382, will tell you how to use a contents & index for a book, I would of done the 1 day course.
Reply to No earth on lighting circuit in the UK Electrical Forum area at ElectriciansForums.net
There is no homework, and I'll never see these photo again.
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
