Hi guys I am re-wiring a bathroom. I have done first fix for fan, down-lights and switches on the lighting circuit. I had to pick an earth up from some old conduit and will of course test this for continuity. Now when I have taken a front plate off of a single socket I have found there to be no earth conductors on the ring cables although there is one in a cable which spurs off of it. It's hard to see if the cables are running in conduit or not which may be acting as an earth if it is. Was this common practise years back, to use conduit as the means of earthing? What do I advise the customer? Does the house require a re-wire? I will try and run my spurs from elsewhere though I think. Any advise welcome. Ta.
