No earth on ring main. | Page 4 | on ElectriciansForums
Discuss No earth on ring main. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
i think the 25a refered to is from a high current stand alone tester (like a clare)
So you don't think a ELI tester provides 20/25A into a test then?? I'm afraid you'll be wrong, they do!!
The Clare testers are used to test continuity integrity on conduit and other metallic containment systems etc...
Reply to No earth on ring main. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
In addition, can you show the junction box with the cover off? Isolate the supply first, obviously. It sounds strange, what you’ve described at...
Generally it would depend on the circumstances whether the armour is earthed both ends or not, and not just dependent on whether it's 2 or 3 core...
