No earth... Zs and rcd | Page 2 | on ElectriciansForums
Discuss No earth... Zs and rcd in the UK Electrical Forum area at ElectriciansForums.net
J
james king
Hello,
Just a quick q....
Went to change a cu and carried out a few test and visual inspections. Found a problam, I think the cable was micc but couldn't tell as none of ends were made off. All cables for all circuits where 2 core NO earth. Zs test on sockets came out with >99kohms....
No I am have a argument with another spark... I think there is no point in installing a rcd cu yet as it wouldn't make any differnce...
What do u all think?
you are wrong !!
how is that wrong obviously a earth would always be better but a rcd only measures any imbalance between live and neutral and if you touch something you shouldn't there will be a imbalance between live and neutral as what is going through you will not be be returned and the rcd will notice the imbalance and operate, you dont connect a earth to a rcd
I would say that the whole of the install would be worthy of a thorough inspection and test before any proposed works proceed as you will just end up inheriting the existing problems. If the MICC has not been correctly terminated then chances are that the magnesiun oxide within the cable could be damp as it is hygroscopic
you are wrong !!
I fixed a problemm recently on a circuit without an earth and the "broken" cable was tripping the RCD
Back to the OP, wouldn't an urgent thorough inspection be required?? I certainly wouldn't touch this install without this first, and probably remedial workk before considering the CU.
i agree. by the way, it's hydroscopic
If MICC, this wouldn't cause the loss of earthing etc, but would cause far bigger problems to this installation!! lol!!
Reply to No earth... Zs and rcd in the UK Electrical Forum area at ElectriciansForums.net
Ok I’ll try this when I’m down
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
