No Inverters | on ElectriciansForums
Discuss No Inverters in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Scrag
South Devon
Just about to be enrolled on register (MCS). Cost so far ÂŁ6000 plus (one man band) and not a penny turned over. I have been given an opportunity to do some subbing and they have supplies except for inverters. Believe they use SMA's and nothing else !!!!!!. Being in at the beginning of the end and desperate to get something back, what is the position of installing everything else and leaving the inverter till maybe after the 12th Dec. Hypothetically, What if one inverter was used for all installs for testing and registering etc and then when supplies come in fit them as required. Any input would be appreciated.
It is a requirement that the installation is commisioned prior to application to the energy supplier. for that the installation requires an inverter. anything else would be fraud.
Anyone wishing to discuss this should avoid doing so on a forum open to anyone
Therefor, if the installation was registered and the inverter failed and subsequently replaced, what is the difference. Not trying to be fraudulent, It was intended to be hypothetical
Reply to No Inverters in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
A picture paints a thousand words so here's an SLD showing my installation and some annotations to show the proposed relocation of the DC...
