No isolation of Neutral in Single phase boards | on ElectriciansForums
Discuss No isolation of Neutral in Single phase boards in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Essex
As title.
Doing an EICR, have come across a couple of DBs, where the neutral goes straight onto the bar on Single phase boards.
Whats your views on this guys?
Should it have a requirement to be isolated? Is there a reg for? If so then it can be coded.
My boss thinks its dangerous. I don't, but I'm happy to have a school day.
The boards have stickers on them, stating supply must be isolated elsewhere before taking cover off as well.
Only required on TT earthing arrangements.
If ordinary persons are using the equipment which equates to households then the main switch must isolate all poles.
The job is a commercial one.
[automerge]1599567757[/automerge]
There is also an argument that the DB should be isolated elsewhere before removing cover. As we know its illegal to work on live equipment.
Also there are a lot of OPDs that are single pole.
Is this Is 230v DB,so main switch should isolate both L & N
It is 230V, but on a commercial install. My understanding is that double is essential on dwellings, to protect Joe public. As its commercial then Joe public will never be working on the system. Only qualified or competent personnel.
Just thinking...what about domestic 3 phase boards? 4 pole isolators?
I suppose it depends on the situation.
Just as an aside....I wonder if Part Peees have been issued for work on some of them big houses (Buckingham and Windsor, for instance).
I'll bet the NIC say they should.
Or Houses of Parliament......plenty sleep in there and call it 'home'.
I have a Hager 3-phase Invicta in my house with only a 3-P isolator switch - ie the neutral is not switched on the board. I was told that the 4-pole disconnector next to and between this dis-board and the meter is sufficient. Would you agree?
As long as the 4 pole switches the 3 phases AND the neutral, then, yes, it’s sufficient. That is the main isolation, not the 3p on the board.
Reply to No isolation of Neutral in Single phase boards in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I really can't see a problem with it assuming there is a neutral there.
Recommended Sponsor News
thanks for the clarification. ( also thanks to Dan. ).
More info on link below http://sbsc.uk.net/
9K
Happy Friday Everyone! Subscribe for more jokes direct to your mailbox or send us your own jokes to be in with a chance of featuring, by clicking...
6K
