No isolation of Neutral in Single phase boards | Page 2 | on ElectriciansForums
Discuss No isolation of Neutral in Single phase boards in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I have a Hager 3-phase Invicta in my house with only a 3-P isolator switch - ie the neutral is not switched on the board. I was told that the 4-pole disconnector next to and between this dis-board and the meter is sufficient. Would you agree?
It's generally not desirable to interrupt the neutral on a three-phase system, unless it's a TT system.
Reply to No isolation of Neutral in Single phase boards in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I really can't see a problem with it assuming there is a neutral there.
