No Luck with Electricians in Scotland | Page 2 | on ElectriciansForums
Discuss No Luck with Electricians in Scotland in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
It seems confusing in Scotland as with no part P, competent person, and limited availability of electricians, how can you trust and check installers?
Unfortunately, as things presently stand, anyone can carry-out electrical work in Scotland. Up here, we have kitchen-fitters, bathroom-fitters and wetpants who are advertising themselves as 'electricians'. I kid you not.
Asking if he was qualified I was assured he was C&G qualified, and could sign off the installation at the end for building control."
Being in possession of a City & Guilds certificate does not facilitate signing-off a building warrant. There are only three ways that electrical work carried-out in Scotland in conjunction with a building warrant can be signed-off:
1. By using a Scottish Buildings Standards Approved Certifier. In this instance, when a building warrant is applied for and the applicant states that they are going to use an approved certifier of construction, the certifier simply downloads a certificate of construction from the Scottish Buildings Standards website, completes it and sends it back to SBS. LA Building Control check the validity of the certificate and sign-off on the work.
2. When the applicant is not using a Scottish Buildings Standards Approved Certifier, building standards will ask for a Minor Works Certificate or an EIC, or even an EICR that has been completed by a SELECT or an NICEIC member.
3. The third option is Reasonable Enquiry. This is the only option available when the person who carried-out the work is not a Scottish Buildings Standards Approved Certifier or a member of SELECT or NICEIC. A copy of the electrician's SJIB grade card must be submitted along with a Minor Works Certificate or an EIC and a copy of the calibration certificate for the test equipment used.
As for the actual work, while I would consider it to be a bit rough, I've seen worse ..... much worse. I have no idea what the intended purpose of the conduit in image 2 is. It's about as much use as window wipers on a submarine.
That short bit of conduit is potentially worse than no conduit - the cable is now in contact with an unprotected sharp steel edge. OK, once it's plastered then there'll be no movement - but that's no excuse.
The third pic is not wrong, but poor workmanship. Once the clipped cable has been trapped like that, pulling in further cables stands a good chance of pinching it and then wearing away at the sheath.
Reply to No Luck with Electricians in Scotland in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
Hi Charlie, this link to the C&G website below has their email address that you have to contact for permission. As someone at the same stage as me...
