R
Ridgey88
Hi Guys,
I have an ergent problem, my usual contractor asked me to wire a new boiler he was installing, and i forgot to check the main bonding before commencing works! I have only replaced a single socket outlet with a s/f spur and connect the a flex to the boiler and upgraded the supplementary bonding.
When it came to filling out the minor works certificate and inspecting adequacy of earthing and bonding i noticed that there was none present!! further more i could not identify the main earthing to the house!! although i got a low ZS (0.72ohms) reading back for that circuit!? so this gives me the impression of a TNS/TNC-S earthing system --note the incoming supply is next to the CU--
How do i stand issueing a certificate etc, i was told by niceic technical helpline that because i had made the circuit live i was now intitled to upgrade the earthing and main bonding at my exspense --How can that be right!!??--
Could someone please give me some advice that is not cut and paste from the regs book.
