Hi Folks, so doing some testing on an installation today and when i carried out the PFC test i was getting a reading of 11A? I tested and retested and kept getting the same result! So, the installation in question is a shed that has had a split load board installed (by someone else) which is feeding several circuits. this is turn is fed from a DB in the house. the DB in the house main earth seems to be a pipe and the guys who did the install said this needed to be rectified and they were going to contact the supplier about it. So they provided a temp earth in the form of an earth rod. earth fault loop test at db = 21.7 Ohms. Im getting earth fault loop tests for all my circuits come back fine, just this PFC coming back at 11A? any ideas? re-checked my tester on my board at home and got a perfectly good reading....any ideas?
