K
kickaha
Domestic CU garage unit. Power is incoming at 237v and registers Live on input and output of RCD. It supplies 3 MCB's on a busbar feed all of which show Live on output as well. Earth is TT and Neutral is on a common bar. Its been fine for 10 years but all of a sudden the lights and ring have just not worked (despite Live output on all of the MCB's). The I changed the RCD as the test button on the old one failed to trip, but the new RCD fails to trip as well.
I used to be an electrician some years ago and only have basic test eqipment now. I suspect a Neutral problem but am a bit flummoxed!
the only odd reading I get is RCD off. L - E at incoming is 237v N - E 37v
RCD on L - E at incoming is 237v N - E 0v
RCD on L - E at outgoing is 237v N - E 0v
I've forgotton a lot of theory so any hints and suggestions as to how I could proceed would be very much appreciated as I can't work on my old Land
Rover!
thanks, Clive
Rover!
thanks, Clive
