No power to whole house after water fell on to cooker??? | on ElectriciansForums
Discuss No power to whole house after water fell on to cooker??? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
A friend has just called as his daughter in Belfast (many, many, many miles from me!) has just lost all power after water fell into the cooker/hob.
I straight away thought it has to be a main RCD somewhere, but I cannot see one in the pictures they have sent and they don't 'think' there is one.
I realise the main switch is switched off on the BS3036 fusebox, they have said it is on now, but still no power anywhere, although I am getting them to confirm if they really mean everywhere as I can see a separate consumer unit doing the shower, so I have asked them to find out if power to the shower. Also, the old black BILL unit supplies the garage, so i have asked them to see if power in the garage.
update... no power to absolutely everywhere (including shower and garage)
Perhaps the main cut out? Really unlikely, but possible.
[ElectriciansForums.net] No power to whole house after water fell on to cooker??? [ElectriciansForums.net] No power to whole house after water fell on to cooker??? [ElectriciansForums.net] No power to whole house after water fell on to cooker???
Obviously the cooker circuit needs checking before re energising
Probably a co-incident, and there is a power-cut, get them to check with neighbours.
I would be surprised if water spilt on top of a cooker would trip an RCD, let along a physical fuse.
Unless we are talking a substantial amount of water......
neighbours light are on.
Reply to No power to whole house after water fell on to cooker??? in the UK Electrical Forum area at ElectriciansForums.net
Thank you, what would be the advice for me to do in this scenario? I've also seen circuits tripped in past from other things such as 1500VA step...
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
