davesparks
But if he chooses a main switch RCD is that something that can be done with a 30ma.
That depends on what type of protection you want the RCD to provide.
But that does not provide the required protection for the buried cabling.I am personally leaning towards putting RCD sockets on all 3 that I have worked on.
Concur. One fault will take out the whole office. Not what you, or the client will want.Not an option IMHO..............
IM sure he said previously that there were 2 mcbs disconnected
Enough room for an rcbo?
if you look at the work you have undertaken on 3 sockets I would go for RCD protection local to the work you have undertaken, after testing the circuit you have joined on to. the reason for this if you put an upstream RCD in circuit & there is a problem on equipment it could trip & you could be blamed for the circuit tripping.No room for RCBO's, CU already chock full.
I think I will speak to the client and see which direction he wants to go. I am personally leaning towards putting RCD sockets on all 3 that I have worked on. But if he chooses a main switch RCD is that something that can be done with a 30ma.
& if for a server I would think twice about RCD protection as above post #42, I would tend to run in a new circuit for server & clean earth.if you look at the work you have undertaken on 3 sockets I would go for RCD protection local to the work you have undertaken, after testing the circuit you have joined on to. the reason for this if you put an upstream RCD in circuit & there is a problem on equipment it could trip & you could be blamed for the circuit tripping.
if circuit / circuits test out okay install a RCD socket outlet issue a minor works anything plugged in will trip your RCD socket only & not trip the whole circuit / circuits, at this point you have protected your work & covered yourself.
Or an RCD socketIMO, he has made alterations to the circuit, at the very least the spured socket should be off a RCD FCU or up front RCD in closure for the circuit in question.
Reply to the thread, titled "No RCD on entire installation" which is posted in Commercial Electrical Advice on Electricians Forums.
