No service head fuse? | Page 2 | on ElectriciansForums
Discuss No service head fuse? in the UK Electrical Forum area at ElectriciansForums.net
1Justin
Surrey
So I was at a 2 bed flat today, ground floor on 4 storey block. 3 years old flats. The supply head holds a red fuse holder reading " solid link, do not fuse". TN-S and the CU is just off the bottom of this shot below the 100A isolator. ~75 cm tails.
"Fuse" is all crimp sealed, I didn't pull it, original DNO work. What's going on here then?
[ElectriciansForums.net] No service head fuse?
I had this in my flat renovation, the meter was fed by a Pyro and wasn't fused at the meter in the end traced the Pyro back to a cupboard in the downstairs flat where the supply was split and fused. The electrician ran a new armoured in from the flat and terminated/fused it correctly.
Reply to No service head fuse? in the UK Electrical Forum area at ElectriciansForums.net
