No sound at TV | on ElectriciansForums
Discuss No sound at TV in the Australia area at ElectriciansForums.net
P
petegibbons
I have 2 televisions supplied off the one sky box. The television being supplied via outlet 1 is working fine however the television being supplied out of outlet 2 is approx 8 metres away and the sound is not working correctly.
Can anyone give me any advice on what the problem may be, I don't really want to use a booster as the television has a magic eye to control it which won't work with a booster but if need be I will have to.
Any advice would be appreciated.
As outlet 2 is an RF signal it could be its clashing with another one such as from a video recorder.You could try switching off any other equipment and connect the outlet 2 directly into the aerial socket to eliminate that.Also check in the telly menue that the channel you are using for satellite is set to the correct UK sound system as some can be set to multiple country systems.PAL I is UK I think.
Reply to No sound at TV in the Australia area at ElectriciansForums.net
Hissing sound from under sink Heya, So there's a hissing sound coming from underneath my sink that feeds my washing machine and dishwasher...
Seo195
From the front cover of the manual: Newlec Helpline: 0800 783 6909 https://www.manualslib.com/manual/3408290/Newlec-Nlsh050.html#manual I think...
