No ZE | on ElectriciansForums
Guest viewing is limited
Discuss No ZE in the UK Electrical Forum area at ElectriciansForums.net
Oh No, please not today
  • [ElectriciansForums.net] No ZE
Hi All
I was carrying out a ZE test yesterday and couldnt get a reading at all on the main bonding.
The main earth cable is only a meter long and terminates onto an earthing clamp attached to the incoming TNCS supply. The clamp has the relevent warning label from the supplier.
I know its not my multi tester as i could get a ze reading from the bonding to the gas and water.
I will be calling the supplier tomorrow, but just wondered of anybody had come accross this before.
cheers
Mark
Can you re-post Friday after 6?
Hi All
cheers
Mark
If you mean a confusing post then sadly yes they are all to common on here!!!!
As Mike rightly said, can you re post on Friday, it is not fair to inflict this upon us on God's day
Op see what you've done now, Tel is gonna end up getting lashed and wrecking the joint, I just hope you're happy with yourself
Reply to No ZE in the UK Electrical Forum area at ElectriciansForums.net
Generally speaking local earthing will rarely be below a couple of ohms, so in parallel with a TN-S sub-ohm value will make little difference...
Thank I'd have already got the spade out :)
Recommended Sponsor News
Hi everyone,
