Non contact voltage indicator - upgrade | on ElectriciansForums
Discuss Non contact voltage indicator - upgrade in the Electrical Tools and Products area at ElectriciansForums.net
England
Hello electricians,
My current ncv indicator I think has had it, and wanted an upgrade. I’ve seen this Sagab VOLTSTICK LV50 AC Voltage Detector | eBay - https://www.ebay.co.uk/itm/Sagab-VOLTSTICK-LV50-AC-Voltage-Detector/193808447576?hash=item2d1fe23858:g:jSQAAOSw-wZf2zTy on eBay and wanted some thoughts advice. Is this brand any good? Should I be dubious about buying such an item from eBay? Ive seen others, but have gotten mixed review from them.
I want it for testing boilers cases and pipes to indicate if voltage is present before working on stuff, not dead testing.
Thanks.
I started with a VoltStick... have no idea where it is now as it was garbage and was quickly replaced by a Fluke. If you're sold on the VoltStick though, that one is designed for 50v AC, you should be looking at one designed for 230v AC.
Thanks. Yes but I’m told it needs to go down as low as 50Vac, which I’m not sure Fluke do one?
My first voltstick IIRC I gave away to a Russian spark in 1997. So the one in my toolbox must have lasted 23 years. No particular complaints although I expect the Fluke might be the best of the bunch.
i have several of these sticks, best one is a sagem 230pro.it has a forked end so behind a switch, will only light on a live conductor in the notch. not picking up from the rest. caveat only used as a rough guide, not for safe isolation. dabbing a L to E does that perfeck.
Reply to Non contact voltage indicator - upgrade in the Electrical Tools and Products area at ElectriciansForums.net
