Non-Electrician Need Safety Advice | Page 2 | on ElectriciansForums
Discuss Non-Electrician Need Safety Advice in the UK Electrical Forum area at ElectriciansForums.net
TATA
England
Hi. Yesterday I got electrocuted when getting out of one of those inflatable Lay-Z Spas and had to go to hospital. I am fine, thank goodness, but I am now trying to address this with Bestway who manufacture these products. They asked me to take photos of the set up I had (plugged directly in to a mains socket, as they advise) and said that they will need to test the socket, so it got me thinking...I fed the lead in to my kitchen and plugged it in to one of the sockets there and there was no indication of voltage in the water when I used my voltstick. When I plugged it back in to my conservatory socket where it had always been however, the voltstick lit up! I have recently moved in to my house and now that I have been here a few months I have started to realise that the painter/decorator who lived here before fancied himself as a bit of a jack-of-all-trades. I think he built the conservatory himself and now also think he wired it himself, as that socket causes my spa water to be electrified!
Where I am more confused though, is that Bestway state that their spas have built-in RCDs that will cut power in the event that water becomes electrified and also if there is some sort of power fault. So even though I seem to have a faulty socket, should the RCD still have prevented the water electrocuting me? I just wanted some professional advice before taking this further, as I can see them trying to use the socket fault as a way to wriggle out of responsibility, or maybe they would be justified in doing so? I just have no idea - any insight is greatly appreciated.
UPDATE: They have sent me an email with the following:
"All of our Lay-Z-Spa comes with an RCD either built into the pump, the cable or the plug which is a safety device which is designed to prevent you from getting a harmful electric shock. You can read more about RCDs at this link. The RCD that we use in our spas is very sensitive – 10 mA cut out which eliminates the risk of a harmful electric shock.
For Lay-Z-Spas made in 2016 and 2017 the pump includes a grounding system, which is double insulated and links all of the electrical parts of the pump directly to the grounding of the electrical system of the house (known as a class I electrical product). The spa therefore relies on the earthing arrangements that you have in the property (and the electrical socket you are using) are up to the required standard.
We would like to arrange to send you a plug-in socket tester. This will provide some indication on the status of the plug being used."
@TATA can i ask a question.
From your last post, am I right in thinking you received this shock when you got out of the SPA ?
What i mean was when you got shocked was one part of your body touching the water the other directly touching the ground (wet foot on grass) ?
Its very important that you arrange a qualified electricain to test this for you.
If you found the earth cable from the backbox loose inside there when you opened it, then it is possible that it could have made contact with the live terminal when it was all squashed in. If the other end of the earth connected to the socket front isnt properly connected, then it is possible the backbox became live, and then connected to the faceplate earth through the screws, which in turn could have made something in the pump case live if it is class I. This would have made the water live, creating a potential between the water and the ground.
Whilst this sounds unlikely to have that many faults, one of them is clearly visable there, and the other one (lack of earth) is not that uncommon.
Either way, if you recieved a shock serious enough to send you to hospital, and you think the wiring is suspect anyway, you should have it inspected ASAP. It sounds unlilely to be a fault with the spa if the RCD is functioning correctly.
The only problem is should you be taking off socket fronts that are known to be faulty? And as for work making you use a volt pen, they are criminally negligent as that in no way complies with a number of regulations and guidance. Please do not rely on it exclusively.
Reply to Non-Electrician Need Safety Advice in the UK Electrical Forum area at ElectriciansForums.net
I seem to recall the last time I read my suppliers smart meter terms and conditions, it suggested the smart meters needed replacing every 5 years!
IMO Better to do something about those ignoring regulations first! Current system is like having a speed limit but not enforcing anyone without a...
