B
Blueflash
Can you easily buy non G83 solar inverters in UK. As in the fact they don't need AC to function?
Discuss Non G83 inverters in UK in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
@Beavstro - Inverters aren't subject to MCS Certification, that's why we're talking about G83
It depends for what purpose, if you would like to be eligabale for the FIT it does. It may betrue for some technologies the inverter doesn't not have to be MCS appreoved I don't know. However for small wind it does. The inverter is considered part of the system.
I have helped put a turbine through this product certification and believe me it is a fact .
Taken from the BWEA small wind certifificarion standard (2008) which if you want to MCS certify (document 006 rev. 1.5) a wind turbine you HAVE TO COMPLY WITH.....
"1.3.3 A turbine system includes the wind turbine itself, the turbine controller, the inverter, if required, wiring and disconnects, and the installation and operation manual(s)."
Which in all fairness makes perfect sense, the scheme was brought into effect to stop cheap crap/ poor installations being sold to innocent consumers, which doesn't then work as it should.
Why would you certify a turbine with one inverter, which is the only inverter it can operate to its full quoted specification, to then sell it with a different inverter which cannot operate the turbine as it should and thus not as its quoted specification. And more importantly is not what was tested and verified by the MCS scheme and thus deemed as an acceptable product?
Reply to Non G83 inverters in UK in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
