non maintained emrgency light wiring help | on ElectriciansForums
Discuss non maintained emrgency light wiring help in the UK Electrical Forum area at ElectriciansForums.net
M
mike123
hi,im trying to connect non maintained emrgency light wire to 1 gang way switch the 3 core wire is connected from light board L,N,E but i dont know where to connect it on 1 gang way switch it has COMM,L1,L2 showing on switch im looking for diagram this will make it easier for me please help.cheers
you need to feed L and N to the fitting, usually from the local light circuit. you will maybe not have a N at the switch.
i have connected right the 3 core wire on the emergency light board where it says L,N,E but the confusing part is where do i connect the L,N on my 1 gang way wall switch do i connect live brown wire to L1,L2 OR COMM and also where does the neutral goes L1,L2 OR COMM i got the earth connection right
correct, you need a double pole switch if you want to switch the neutral, you have no idea what your doing unfortunately, it is very simple really, what have you actually done? just pulled a 3 core and earth from the light to the switch? a 2 core would have done, but you need a neutral at the switch to make it work and I suspect you have not, so up the creek without a paddle.
OOOHHH BANG I HEAR!!!!
LIve only goes to the switch , Neutral goes to the light fitting, if you have only 1 twin and earth down to the switch then you can only switch the live , if you want to swich the neutral as well you would need 2 cables ( 2 lives and 2 neutrals and then you would need a double pole switch , not fully sure what you want to do!!
your not answering the question, have you got a neutral available? you may have connected into the neutral terminal at the light, but have you got somewhere to connect it in the switch?????? I suspect no, so whats next?
Reply to non maintained emrgency light wiring help in the UK Electrical Forum area at ElectriciansForums.net
Thank you so much for your help with this light work perfect now thank you again much appreciated
Ah yes my apologies, thank you much appreciated.
