Spazz
I have just replaced a number of socket fronts in a property like for like - therefore non part P.
They want an insulation certificate, which I have no problem with. I am therefore giving them a miner works certificate, do I need to include the Scheduled Inspection Sheets for socket front covers as well as the test results or are they not required in this case?
I will be coming back in a weeks time to change the CU where all the tests will be done then.
I have tested each socket as I fitted them individuality, and know they are all up to standard.
Thanks in advance
Thanks in advance
