non rcd covered circuits | on ElectriciansForums
Discuss non rcd covered circuits in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
south west
doing some kitchen moving around for a guy, 16th board with rcd in the middle, rcd feeding pv,and about four circuits, on the other non rcd side is cooker,up sockets, down sockets lights up lights down,
should i install longer busbar and move cooker and lights over "ones i work on" or just rcbo the ones leaving the board same but protect altered circuits,
your thoughts please.....
Personally I'd RCBO them, saves messing around trying to alter the board too much and leave a bit of segregation for the circuits if the RCD trips.
Reply to non rcd covered circuits in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Regulations notwithstanding, the only thing in those pics that is likely to be affected by sheep is the trailing flexibles on the ground from the...
Exactly. I was going to ask on the earthing once he clears this boiler fault (suspect on internal component). OP mentions oil boiler but makes no...
