NoNoNo why do i always get them | on ElectriciansForums
Discuss NoNoNo why do i always get them in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
N
nickblake
been to a job to look at a job where there have been numerous sparks and yet again its bodgit electrical leaving a dangerous condition attatched are some pics how i found them supply polarity incorrect , covers missing from meters exposing the terminals these are on differant phases so 400 volt potential , opps ive blow a fuse say bodgit never mind an bit of 1.5 should do the trick , just put the cover over that broken fuse it will be ok ,there are 6 meters supplying 6 flats all off a supply into henly blocks and then into switch fuses , think ill get the DNO in to put in seperate fuses and meters make life alot easier, so its head downs and work out how it can be sorted out again[ElectriciansForums.net] NoNoNo why do i always get them[ElectriciansForums.net] NoNoNo why do i always get them[ElectriciansForums.net] NoNoNo why do i always get them
How about this one then, not as scary as the CU above.......
And yes it is 4 x T&E into 13A plugs into an entension, off another extension..
Was called in by a builder his electrician had decided not to return, turned out every trade including the building company were cowboys, big mansion in Surrey extension job.
That board was a month old in first pic they paid £3000 for that mess
It took 4 days including testing to rectify to second pic
I found bad work all over the place
Reply to NoNoNo why do i always get them in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
With what looks like only 5 circuits you can probably put a little 5 way garage consumer unit in there if money is tight
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
