R
rocker
Hello all, screwfux are advertising their standard 25mm SWA glands as 'IP54'. They are just normal Tower 2 part glands and I can't see any sort of rubber ring in them. Is this rating correct? A thousand thank-yous!
Discuss Normal glands waterproof?? in the UK Electrical Forum area at ElectriciansForums.net
The IP54 rating will just be for the gland and shroud, with the shrould uncut. Therefore as soon as you cut the shrould, it technically looses it's IP rating....!
i always use CWs outside. in fact, i prefer to use them all the time as they grip the armour more securely than the BWs.
Reply to Normal glands waterproof?? in the UK Electrical Forum area at ElectriciansForums.net
