- Joined
- Jan 7, 2011
- Messages
- 50
- Reaction score
- 5
Hello All,
After posting about a CU change and the one light circuit that kept on tripping the RCD on the new CU i had a lot of great advice. Armed with my Megger 1553 i approached the CU and condcuted some IR and continuity tests.
At first a borrowed earth was suspected but from the following test results i think maybe not. I think there is a small IR fault and defiantely a fault to earth on the circuit 2. Seen by the resutls below. Can some one confirm that it is possible to have a small enough earth fault that will not trip a normal over current protective device but big enough to trip the more sensitive RCD protective devices.
If indeed i do have an earth fault, how can i go about finding it without ripping up half the house to find it?
cheers
DD368
cheers
DD368
upstair lights = 1 | ||||||||
downstair lights = 2 | ||||||||
IR test | P/N | P/E | N/E | |||||
1 | 99.9 | 99.9 | 99.9 | (MΩ) | ||||
2 | 0 | 0 | 0 | (MΩ) | ||||
nb switches off, 250v used with loads & Dimmers in | ||||||||
Continuity | ||||||||
P1 | N1 | CPC1 | P2 | N2 | CPC2 | |||
P1 | _ | open | open | open | open | open | ||
N1 | open | _ | open | open | open | open | ||
CPC1 | open | open | _ | open | open | open | ||
P2 | open | open | open | _ | 69.3Ω | 69.3Ω | ||
N2 | open | open | open | 68.4 | _ | 0.27Ω | ||
CPC2 | open | open | open | 68.4 | 0.27Ω | _ | ||
continuity is evident between live conductors on circuit 2, possibly due to switches in on position | ||||||||
however there should not be any continuity between live conductors and CPC. |
