not getting 240v | on ElectriciansForums
Discuss not getting 240v in the Australia area at ElectriciansForums.net
C
chrisgb82
im a builder just finished refurbishing a house and had a call from the house owner saying hes only getting about 195 volts out of his living room sockets does anyone know why this could be?
Have you rang the spark who installed them? You could have a loose connection between the sockets. Could be a supplier problem if its throughout the installation!
ill check its def only living room but thats what i was told over the phone, so a loose connection can def make you lose voltage ? i didnt realise this could affect voltage but thanx
You could try and find the mid point of the ring using r1&r2 calcs but in all honesty I would remove all the fronts and check all the connections,don't mess about as you may find other loose connections there.It happens to everyone but I would say the testing side should have picked this up?
If you are dropping voltage,best get it sorted and tested
Low voltage and modern electronic equipment and appliances dont make good bedfellows
Could become an very expensive problem
Reply to not getting 240v in the Australia area at ElectriciansForums.net
I went to look at a job like this a few years ago. My customer had a rental house, where there was an upstairs bedroom that had a newly built stud...
    • Informative
By code the washing machine needs its own 20 amp single pole GFCI circuit, the dryer needs a 30 amp double pole breaker and using # 10 wire. Your...
