T
tri cal elec
but if anyone can help me solve this little problem Id be greatfull
Light needed in a room
-Drilled into concrete ceiling and put what I have no idea what it was called now into the whole. Found that the 8 ml drill bit the matey said id need was a bit of a tight fit to get this raw plug shall we say into.
anyway after getting it in, with a hammer! I had to punch the middle of it so that it splayed out. someone will know what there called im just trying to describe it. did that threaded me m8 i thnk he called it bar into it, for a good few turns then put a washer on top with a nut to hold it.
took the light drilled out a 8ml in the centre threaded a nut up the m8 bar, popped the light on and put another nut on the inside to hold it. drilled another hole into the side of the light and put a glad onit for the cable to enter. prob is im finding it wobbles and sways like a barstard, id say the drop of the bar is 1.5 m
I think onother bar dropped down would steady it. perhaps you can buy some sort of clip/clap that can attach to the m8 bar and a random pipe that just so happens to be there for it to grab onto which would be more ideal as its a bit of a tight gap to drop another bar.
anyone wanna say what they would have used/done?
